calling a labview dll with CVI/Problems with LStrHandle
I'm trying to use a labview DLL (which I can't modify since I've no access to the source) in CVI. The function I use needs 1 LStrHandle as input and 2 LStrHandle as output. But I'm getting the following error message when I'm executing the function :
"error #3: "memory.cpp", line 563, labview 6.1"
I've tried to allocate memory to the handle but I'm not sure at all what I'm doing (when not doing this, I receive a general protection error) :
  hraw = (LStr**)DSNewHandle(sizeof(LStr));
  hout = (LStr**)DSNewHandle(sizeof(LStr));
  houtp = (LStr**)DSNewHandle(sizeof(LStr));
Thanks for helping,
Arnaud
(3,015 Views)
Hello Arnaud,
I find the following forum post that discuss the
Error #3 memory.cpp line 563
The error seems to be causesd from the LabVIEW DLL and not a CVI/Problems with LStrHandle
But could you post the cvi-project and the LabVIEW DLL, so that we can reproduce the error.
Best Regards
Benjamin
(2,986 Views)
Hi Benjamin,
Thank you for your answer.
Unfortunately, the other post didn't help me much.
The dll is provided by another company and so I cannot put it on the web without their agreement. Concerning CVI, I've tried to just declare the handles and to call the function contained in the dll. So basically I have juste this:
 LStrHandle hraw, hout, houtp;
dll_function('parameters');
Thanks again.
Arnaud
(2,982 Views)
Hello Arnaud,
take a look at the following
KnowledgeBase
"Error 3: memory.c line 593" When Passing an Array Handle to a LabVIEW DLL from External Code
Best Regards
Benjamin
(2,954 Views)
