ā03-01-2007 04:43 AM
hello
i was using USB6008. i am also using PCI 6036E to compare with the performance
from USB6008.
i think it is not the matter of number of sample.
i think of one solution(Whether it is working or not).But i dont know how to
implement it. i may need
the silly idea i think is that if i put sampling rate 5000 Hz and number of
sample 2500.
then the actual signal with 2 peak will be seen as 2 continuous signals with
one peak. therefore, actual signal with 4 peak will be seen as 4
continuos signals with one peak.
poor enough, i have tried to use append signal to combine this 4 continuos
signals(single peak) as one signal which has 4 peak. but it doesnt work.
here attached with simple diagrams
from the diagram, if i set the sample number as half of the sampling frequency,
the signal A will appear in graph indicator before signal B.
my idea is to append these signal A and B to become the original signal(which
has 4 peaks).is it possible to be done.i have tried to build array, to create
shift register.but it didnt work for me.
thanks for the assistance.
regards
ā03-01-2007
06:15 AM
- last edited on
ā12-22-2025
09:15 AM
by
Content Cleaner
Why not replace your graph indicator with a chart indicator??
Only thing would be you may have to specify a large enough 'chart history length' to hold more than 5000 samples
Message Edited by devchander on 03-01-2007 06:15 AM
ā03-01-2007 06:15 AM
ā03-02-2007 09:26 AM
ā03-02-2007 10:44 AM
ā03-05-2007 04:35 PM
ā03-07-2007 06:26 AM
ā03-07-2007 06:34 AM
ā03-08-2007 11:20 AM
ā03-08-2007 11:21 AM
