appending zero number to string conversion
So I have a 0 in int format. I want to convert it to a string so that it says "00." Is there an easy way to do it in labview? or If I have 1 in int, I want to convert it to a string value of "01." Help?
Thanks!
(4,274 Views)
Accepted by topic author d1sturbanc3
You just need to use %02d as the format specifier with  your Format Into String function. If you move your mouse over the function and right click, you can select 'Edit Format String'. The popup will provide help.
(4,264 Views)
You can use "Format into String" with a format of "%02d."
Change the 2 if you want a different number of digits. Omit the "." if you don't want a decimal point.
Rod.
EDIT: Bother, too slow in typing! PS. Still check out the decimal point!
Message Edited by Rod on 19/08/2009 17:01.. 05:01 PM
(4,259 Views)
