Using DAQ Assist. can I create a VI that measures continuously for a fixed time?
I'm using LabView for a NI USB-6009, with two accelerometers as my analog input. When using DAQ Assistant to build my VI I didn't see an option for measuring continuously for a fixed amount of time. I need the test to run for two seconds then stop.
Is there anyway to specify the exact time length of each test?
(2,704 Views)
Accepted by topic author Dunh
That's about as simple as you can get. Set the number of samples to be twice the sample rate (or whatever multiplier you want). That's it - a single DAQ Assistant and nothing else on the block diagram. If you need it to be variable, just wire a control to the number of samples input.
Message Edited by Dennis Knutson on 08-18-2009 02:17 PM
(2,694 Views)
Thank you! What a simple solution!
(2,673 Views)
