change font of a portion of text in ring menu
I would like to change the font of a portion of a text in a ring menu but it seems that it's more complicated than expected.
I tried to adapt this (http://digital.ni.com/public.nsf/allkb/6BD344ACA4DEE20A8625692700737E16) to my purpose.
Here is my VI
You will notice that the entire text is changed...
(3,199 Views)
the reason for this is that you can't do it. essentially, you can use that method only when you can change the font of a portion of the text in the edit mode. In case of your control, you have no provision to do that. Probably you should use picture controls... 🙂
(3,181 Views)
Ok! thanks, i'll have a look at it more in detail when I have the time. For the moment, I just added the symbol I wanted beside the text.
Chris
(3,159 Views)
