Showing results forĀ
Search instead forĀ
Did you mean:Ā
application builder 8.2
I am building an application in 8.2 using the same startup vi I did when I built it in 8.0.  I do not want my application to run when opened.  Under source file settings, the Property "Run When Opened" I have selected "Use VI Setting" , however after I build the application it still runs when opened even though on the startup vi  "file>vi properties>execution>run when opened"  is not set.  When using 8.0 all I do is unselect both the Run When Opened property and the Value option and it worked fine using the same startup VI.  I have tried all known possible combinations to prevent my vi from running when opened.  Once again I did not have this difficulty in 8.0.
Any ideas?
Brian
Brian
(4,519 Views)
Hi brianlachlan,
This is a detail that we found in the version 8.2, this version does not provide this functionality, but it's been taking care off.
Sorry =(
Tania Lozoya
Mensaje editado por Tania Lozoya
(4,514 Views)
Thanks Tania,
So will there be a patch soon for 8.2?
Brian
Brian
(4,503 Views)
Hi there!
It is a problem that should be fixed soon, but for now lets see a workaround to solve this! 😃
What you can do to fix this is, go to the Advance page, and check  "Enable debugging" and "Wait for debugger on launch".
That's it!
You will have the same effect!
The only side effect, is that the .exe file is going to be bigger, because in the build, it includes files that the executable needs to enable the debugging option.
There are more things you can do, but this works fine.
If you have any problems. let me know!
Tania Lozoya
(4,431 Views)
As Tania mentioned, there is an existing bug report for this issue.  This was reported to R&D (# 40HEDDJG) for further investigation.
Thanks!
Travis H.
LabVIEW R&D
(4,354 Views)
