appropriate filter
Toyota,
The despiker uses an array of data as input. You do not need to build the table. You may modify it as necessary.
Lynn
Message 21 of 23
(768 Views)
Dear Lynn,
Thanks for your reply. I could not manage to connect output of measurement data from HP to  array of data  from HP despiker program although I tried many times. According to the error report from Labview , it stated that I am connected to the output of subvi. I think array of data as input and interpolated data as output. How can I manage to modify in order to connect ?Please let me know your suggestions.
regards,
Toyota
Message 22 of 23
(759 Views)
Toyota,
Please post your VI which has the problems. There is probably a simple explanation, but without the current version of the VI, it is very difficult to tell what is wrong.
Lynn
Message 23 of 23
(752 Views)
