Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
aquerir from parallel port with labview
fethy
Member
05-05-2006
09:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to aquerir digital data from parallel port of the PC then representing them on a graph with labview.
How can i do that ?
finaly thnx.
0
Kudos
Message
1
of 2
(2,963 Views)
Reply
Re: aquerir from parallel port with labview
NIquist
Trusted Enthusiast
05-05-2006
11:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can use the port in and port out VIs found in the Advanced>Port I/O palette. For an example check out 'Parallel Port Read and Write Loop.vi'.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
0
Kudos
Message
2
of 2
(2,953 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
