can anyone give me a very simple example of python script that i can use to run my labview vi.
I have little experience of python, and all the blogs seem to only give me scraps of info. I have read the labview manuals and they seem to suggest that I use active x to run my labview vi's from python. What I need is a very python script that will open and run a V.I. So i can test my labview active x server works. Help !!
(2,724 Views)
Hi Panicman,
I am not too familiar with Python.  I had a search around the web and came across LabPhyton.  It is a node quite similar to a fromula node which allows you to insert your Phyton script.
Check the following links.
http://www.jpaulmorrison.com/cgi-bin/wiki.pl?LabView
http://forums.lavag.org/lofiversion/index.php/t1107.html
If you are still having difficulty let me know.
rgds,
Seamus C
(2,702 Views)
