arbitrary signal generator, FLUKE 284 connected to LabVIEW
good afternoon, excuse me:
How to read three channels of an arbitrary signal generator connected to labview ?. The model of the generator is fluke 284.
All I want is a time of 10 seconds to show the signal from channel 1, then the signal from channel 2 for the same time and then the two channels at the same time. In 10 seconds each case.
(2,393 Views)
Do you want us to research for you how to get data from your instrument directly into LabVIEW?  If it's a signal generator, is it generating a Voltage Signal that you want to sample?  Do you have DAQ hardware to do the sampling?  Have you written any LabVIEW Code that you are trying to use to do this, and need a little help because some step isn't working?
If you are looking to hire an experienced LabVIEW Developer to do your task for you, there is a Special Interest board here, LabVIEW Developers Seeking Employment, for doing this.
Bob Schor
(2,360 Views)
