arc monochromator driver
HI JOHN,
i work with vi's you have given me and i am able to run that vi's .I can change wavelength ,grating. but know  i also needs vi to change scan-rate  and scan wavelength from inital to final with time delay. So if i have to create vi ,how should i do that. Do you have vi for this also?
THANKS A LOT
JOSAN
Message 21 of 22
(714 Views)
Josan,
The vi's that I sent were intended as examples.  Certainly you can put the wavelength vi in a timed loop and "scan" over a series of wavelengths.  You can set a starting wavelength and an increment.
Have you gone through the LabVIEW tutorials?  I believe that these would be beneficial to you in understanding how to unlock the power of the LabVIEW programming environment.
John
Message 22 of 22
(709 Views)
