arduino error 5005
I'm using LabVIEW to control my Arduino, I had experience with DigitalWrite, AnalogRead and it works. But an error 5005 occurs when I put "AnalogWrite" to control the brightness of LED.
And I tried it still works if I remove this "AnalogWrite" and only "AnalogRead" in the while structure.
I request your expertise to fix this problem, thank you.
(4,303 Views)
(4,275 Views)
Accepted by topic author michaelcwang2
Thanks and I also find another answer which might be close to my situation since communication port recognized if I keep analogread vi.
https://www.labviewmakerhub.com/forums/viewtopic.php?f=12&t=323&p=1923&hilit=arduino+uno+error+5005#...
But really appreciate your prompt answer. I'll both later once available.
(4,243 Views)
