compare two array with cluster inside
I'd like to compare two arrays that contains a cluster with several clusters in it. When using the equal fonction the result has the same schema as the input cluster. But I just need a true or false. It doesn't bother me wether it changed on position1 or any other position.
Is there an elegant way to do this?
Thanks for any help.
Yves
(3,684 Views)
Accepted by topic author Yves
R-click the Equal and change to Compare Aggregates. That, or add an And Array afterwards. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,656 Views)
