areaundercurve
actually you can add a new table with all values and the existing table you can keep as it is since this would be the sum of all
Message 21 of 37
(1,665 Views)
I am trying to do something like that which you already did for another program.
Attached
The new values store indvidually
Similar to this
Message 22 of 37
(1,647 Views)
That's what I had in mind too. Were you able to adapt it to your problem. Should be quite easy.
Message 23 of 37
(1,635 Views)
i am trying
bu not been able to run the vi because of error
Can you give an idea how to add shift register with the String
Message 24 of 37
(1,626 Views)
Message 25 of 37
(1,621 Views)
If i were to take seperate readings for each cycle, this is actually what i wanted to do.
For example if i have area values for above and below and i would want to repeat the same, the next row should contain new values
that means the next the cycle will start reading from 0- so on for each above and below areas
At the moment it is quite similar to what you had before, the next values add to the previous.
Message 26 of 37
(1,613 Views)
Altenbac
Message 27 of 37
(1,571 Views)
Altenbach
i am unable to figure out how to take the values so that the new values start from zero, i.e. should not add with the previous values.
Its fine until with your latest program but values keep on adding and donot reset after the cycle is complete
Message 28 of 37
(1,570 Views)
i have simplified a program little bit and taking values for Above area only.
But i would like to know how can i reset values when a cycle is complete
Attached
Message 29 of 37
(1,546 Views)
Sorry, I don't know what you mean.
(Also, waht is up with that weird code construct, taking a scalar, turning it into an array with a single elements, the integrating it with simpson's rule, then indexing the single element out again???)
Message 30 of 37
(1,535 Views)
