array management
hey
How do you get a array to re-fill. im filling a 1d array with 10 elements, i want it to go back to element 0 and re-fill the 10 elements with new values. the array is inside a while loop, and with each iteration of the loop a new value is generayed and sent to the array.
thanks.
Brendan
(2,912 Views)
Hello Brendan,
you will have to make your own logic!
You could take the loop counter (i) and put that on a quotient/remainder with divisor 10. So you get an index to the array in the range of 0 to 9...
(2,907 Views)
Hi Brendan
In addition to what GerdW already mentioned (which is absolutely right), use the "Replace Array Subset"-Function from the array-palette to replace the elements.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,902 Views)
