array manipulation
I would like to manipulate and array like this.
12 42
22 32
13 43
23 33
to
12 42 13 43
22 32 23 33
How would I go about doing this?
Message 1 of 9
(5,123 Views)
Use Transpose 2D Array:
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 2 of 9
(5,118 Views)
It's not actually a transpose that the OP is looking for.
Need more information about what operation the OP is trying to do and whether it is scalable.
It looks like the OP wants to do a split and then reassemble.
But this is almost certainly not what the OP really needs.
Message 3 of 9
(5,111 Views)
Reshape transposing rows and columns
(Note: I bet the array buffer allocations aren't necessarilly real)
Message 4 of 9
(5,102 Views)
Jeff, all you did was a Transpose 2D Array.  Look at the example closer.
Here's what I came up with really quick.  It is scalable.
Message 5 of 9
(5,097 Views)
thanks. What is that double orange block on the output of the for loop?
Message 6 of 9
(5,075 Views)
I told the FOR loop's output terminals to "Concatinate".  Right click on the terminal and go to Tunnel Mode->Concatinating.  That was introduced in 2012, so if you have anything older, we will need to have some fun with shift registers and Build Array.
Message 7 of 9
(5,068 Views)
Well not exactly but, is see after closer examination its even rows appended in order on row 0 and odd rows to row 1 from the OP's post.
Message 8 of 9
(5,058 Views)
*Edited,cause is not working as expected*
Message 9 of 9
(5,031 Views)
