array manupulation
Hi muks.
I've scanned through the picture file You've posted.
There seems to be a lot of gaps between the "255" 's that are larger than the 1500 indexes You wanted. (the largest gap being 15281)
How to handle such situation???
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 11 of 42
(3,737 Views)
Hi Bcl ,
           You are right and i am still stuck.For your condition i need to divide the difference if the next 255 is occuring between a period greater than 1500,Then the difference need to be divided by 1500 and get its absolute value and insert 255.Sounds very complicated????Yeah and i am breaking my head.
Message 12 of 42
(3,709 Views)
Hi muks.
I already thought You'd say that.
I'll look into it.....
BTW.....I figured You need this VI for decryption of images, but for what application?
Message Edited by BCL@Servodan on 06-20-2008 10:29 AM
But there's NOT
LabVIEW 2012-2017
Message 13 of 42
(3,705 Views)
My application is customized ccd camera.I am still stuck.
Message 14 of 42
(3,685 Views)
I've been trying to follow these multiple threads on what seems to be the same subject, but now I'm thoroughly confused as to which one I'm supposed to look at or respond to. Smiley Sad
Message 15 of 42
(3,680 Views)
There should be a way to link the thread...
.... then again, that would be way too confusing..  😉
Message 16 of 42
(3,680 Views)
sorry guys please reply in this thread only.
Message 17 of 42
(3,671 Views)
So where's this picture file that people are referring to that has been supposedly posted?
Message 18 of 42
(3,662 Views)
Here is the image
Message 19 of 42
(3,642 Views)
Accepted by topic author muks
Hi muks.
Sorry for the long delay. (Iv'e been pretty busy)
I've made this little VI for You. It works the way You described (or at least as i thought You wanted it work).
Still when running the sample image through it, the outcome is pretty "messy".
Give it a try and tell me if it's OK.
But there's NOT
LabVIEW 2012-2017
Message 20 of 42
(3,584 Views)
