array manupulation
Hey BCL U r simply tooooooooooooooo good.Thanx a ton bro.
Message 21 of 42
(2,779 Views)
It is working nicely and requires a lil bit of finetuning.Will do it and keep you updated.Thanx once again
Message 22 of 42
(2,778 Views)
Hi BCL,
             Can you suggest me on how to do auto correlation and cross correlation on this image?
Message 23 of 42
(2,751 Views)
Hi Muks,
Can you tell me what software you are using to create and manipulate this image? If you are using anything like Ni-Vision or IMAQ, please create a new thread and specify that you are using vision software.
Ipshita C.
Message 24 of 42
(2,729 Views)
I am ofcourse using labVIEW,NI-Vision and IMAQ.
Message 25 of 42
(2,706 Views)
Hello muks,
Check out this thread related to IMAQ and NI-Vision functions, and post any new questions there. I hope this helps 🙂
David G
Sales Engineer - SE Michigan & N Ohio
Message 26 of 42
(2,677 Views)
Hi BCL,
            Please check the images attached.I have got the image after aligning.Still i am not able to get the desired o/p.Do you see something going wrong with the alignment?
Message 27 of 42
(2,636 Views)
Please attach some real data.
Message 28 of 42
(2,623 Views)
muks wrote:
Hi BCL,
Your image "realtime images alignment.png" is a 24bit image and does not contain a single 255 value.
Can you attach a real encrypted image that is 8bit and actually contains something that is 255.
Message 29 of 42
(2,607 Views)
I am getting an 8bit image only.I have saved it wrongly i suppose.Please see the attachment. See the leftcorner u can see all the 255s there.See the attachment please.
Message 30 of 42
(2,586 Views)
