array of data to MS ACCESS
I am trying to Insert 52 fields of data In MS Access. One error display repetitive as attached in Image.please help to resolve this.
Message 1 of 13
(6,074 Views)
It's tough to say without seeing the data in the "columns" control.
Jim
Message 2 of 13
(6,072 Views)
hi,
PFA of BD and FP of Vi.
Message 3 of 13
(6,060 Views)
From the image, your code does not make any sense. The for loop repeats 52 times with the exact same data. Are you wanting 52 rows with the DBL array constants in them?
Message 4 of 13
(6,034 Views)
That vi doesn't help; the "columns" control is an empty array.  You need to save the data as the control's default value.
Jim
Message 5 of 13
(6,000 Views)
A couple of things:
- Replace the Database TimeStamp with a Get Date/Time in Seconds and use the Format DateTime String with this: %Y-%m-%d %H:%M:%S
- I don't think you can place an array into a field like you are attempting with that last bundle element. I've never tried it but I believe you need to break that down into the elements that are within that array.
What is your overall goal here?
Message 6 of 13
(5,979 Views)
I  Want to add 52 fields in MS Access via attached Vi.but this error occurs repetitively.so, I wired N-terminal.
Please help in this matter.
Message 7 of 13
(5,926 Views)
Your code still does not make any sense. Your dbl array is empty. You need to write one row at a time. The data does not change. You need to create an array of rows, not a single one with an array in the cluster.
Another reason to avoid the toolkit. It hides so much and allows for really silly code.
Message 8 of 13
(5,916 Views)
Message 9 of 13
(5,878 Views)
Please tell me how can i insert 52 Fields in MS Access database and respective records to each  Fields. this error occurs repetively.
Message 10 of 13
(5,852 Views)
