Mouse control
I work with microscope live-imaging where I need to click an object on screen and move it.  I would like to create a VI that can automatically click said object, and move it in a designated way without any user input.  More specifically, I would like the VI to essentially click on the object (this part could be manual or automated), then while holding the click, oscillate movement a set amount in a stright line (left/right or up/down, does not matter).
So, again, the VI would click and hold this object, then oscillate the cursor back and forth a set distance and for a set time or until the use ends the program.
Any tips would be appreciated.
(5,112 Views)
Their are some windows dll which helps to do this application
go through this link their is a discussion which happened already about this
find the attached example code.
Thanks & Regards
Varaprasath M
Certified LabVIEW Architect
Certified TestStand Architect
(5,072 Views)
