array title
Hi
I need help to under stand something in labview  , that some one use in previous project
attach file
what I am asking as you can see in vi that I attached there is array that include cluster
how I can fit the title of the array that can fit the indicator inside the cluster ?
I don't know how the previous test engineer do that , how he create the title , and if I need to fit it how I can do that
nots the vi create in labview 2015
 appreciate your help
thanks alot
Message 1 of 8
(5,256 Views)
Accepted by Elyan_wisam
looks like custom cntrol
Message 2 of 8
(5,245 Views)
"titles" of controls, constants and indicators can be set through their labels.
Right click and either select "show label", or "properties" and then change the label there.
Message 3 of 8
(5,240 Views)
R-click an element in the cluster and Visible items -> Captions, and see what happens. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 8
(5,215 Views)
I am always learning something in the Forums!
I understand the Cluster labeling (I do it all the time, myself), but I don't understand how the O.P.'s "previous Test Engineer" or Artem.SPb created the "above-the-Array" "column labels" that show up in the Grey boxes.  When I've wanted to do something like this (usually because I didn't want to see the Cluster Labels on each Cluster Line, but wanted a single Label Strip at the top), I made a Text Decoration with the Labels and then "grouped" it with the Array as a Custom Control (as Artem.SPb suggested), but that doesn't seem to be what was done here.
What's the New Trick?
Message 5 of 8
(5,206 Views)
As Artem.SPb said, it's a customized control with 'label' decorations (given a background) placed where desired.
Message 6 of 8
(5,189 Views)
Hi
I try it and nothing happened
I don't think that  the title is related to cluster
Message 7 of 8
(5,170 Views)
If it is, indeed, a Custom Control, then you need to find the .ctl (Control) file that defines it, which is where the Decoration that sits on top of the Array of Clusters and names the Columns is defined.
Message 8 of 8
(5,148 Views)
