array to spreadsheet eol
I am using array to spreadsheet.  I notice that there is always a eol at the end.  Is there a easy way to get rid of the eol?  Thanks!
Kudos and Accepted as Solution are welcome!
(4,354 Views)
Someone can probably come up with something more elegant, but here's the dumb and stupid way...
(4,350 Views)
Accepted by jyang72211
Correction for the above: EOL is different based on the OS. Thus, you'd need to account for the actual length of the EOL "character".
An alternative is to convert the array to a string array and then use the Join Strings VI (not in the palette). You can find an example here: http://forums.ni.com/t5/LabVIEW/Darin-s-Weakly-Nugget-1-10-11/m-p/1409328
(4,344 Views)
Put a "Trim Whitespace" function after Array to Spreadsheet string, and set it to trim whitespace from the end.
Of course, this will cause problems if your last spreadsheet cell may actually contain whitespace characters, but otherwise it's fine.
(4,338 Views)
Or this?
I believe that using the "EOL" constant from LabVIEW's string palette will take the length of the EOL into account regardless of OS?  I might be wrong, though.
(4,336 Views)
(4,319 Views)
