Hello! I have a problem with the arrays in Labview. My array has variable dimensions, it depends of the number of channels and the number of readings I want to do. The structure is something like this:
10 15 20 40
10.1 15.1 20.1 40.1
10.2 15.2 20.2 40.2
The first row is the first reading of all the channels. All the readings in the same column correspond to the same channel, so 10 10.1 and 10.2 are three readings of channel 1, 15 15.2 and 15.3 the readings of channel 2, etc.
I want to calculate the standard deviation of every channel, but how can I do it? I can do it for all the channels, is quite easy, the problem is to separate the channels. I tried to transpond the array, but the problem is that the option only exists for a 2 D array.
I have no idea how to do it, so if someone can suggest me something I would be very happy.
Thanks for your time.
Vicente
