arrow key function in front panel
Hi Somil,
According to ur experience, do you think this VI is suitable for simulating a movement of a needle ?
Initially I wanted to show a needle and its movements as I change the values.
But I could not do do. Instead I had to adapt to this method.
Do you have any other better solutions to my issue>
PLs do advice.
Thks N Rdgs
Titano
Message 21 of 67
(2,838 Views)
i am attaching a vi.
this is not exactly what you are asking but something similar.
Somil Gautam
Think Weird
Message 22 of 67
(2,833 Views)
Hi Somil,
Thx for the Vi.
The models are of certain file type which has to be CAD drawn, I guess.
Unfortunately I dun have such models or software to do this.
What are the sensors for actually?
How can i possibly implement this to my case since it involves plotting?
 PLs do advice
Thks N Rdgs
Titano
Message 23 of 67
(2,830 Views)
see, i told you earlier that i havent played with 3d things.
 you want to rotate the needle as you update the values. put your code in a while loop with wait for front panel activit function
also, see this vi also. i  found this on the internet
Somil Gautam
Think Weird
Message 24 of 67
(2,824 Views)
HI Somil,
Thanks for the vector Vi.
I do not understand;
what do you mean?
Any examples I can refer pertaining this?
Thx for ur help
Rdgs
Titano
Message 25 of 67
(2,822 Views)
see attached.
also, see this if it is of any help
Somil Gautam
Think Weird
Message 26 of 67
(2,820 Views)
Hi Somil,
Thx for ur guidance this far. Really appreciate it.
I will start workin on this and will get back if i face any queries.
Hope to see you agn.
Any other way I can get to u other than this forum?
Thx N Rdgs
Titano
Message 27 of 67
(2,815 Views)
email
somil_gautam@yahoo.com
ec.sg@tatapowersed.com
Somil Gautam
Think Weird
Message 28 of 67
(2,811 Views)
Hi Somil,
Sorry to bug u agn..
Do u have any idea how to play around with digital waveforms?
My issue is;
When I press a boolean switch which runs a number, the digital waveform shows a 1.
The other way round, it shows a 0.
This has to run concurrently with the boolean switching, meaning it updates at every instant.
 Pls do advice.
Thks N Rdgs
Titano
Message 29 of 67
(2,807 Views)
Elaborate more
what i have understood is, that you want a waveform to show 1 when you hit a boolean button and 0 otherwise. Is it?
Somil Gautam
Think Weird
Message 30 of 67
(2,803 Views)
