articial horizon indicator
Hi, anyone know if the labview have this kind of indicator?
This is called artificial horizon indicator and is used in flight simulators
Message 1 of 11
(9,026 Views)
We know what it is. Smiley Wink Did you try a search?
Message 2 of 11
(9,014 Views)
I don't think LabView has anything like that as a native control but you should be able to create your own - (or start from someone else's).
One way would be to create graphics of the various overlays (eg a blue/brown graphic for the horizon, a white slew indicator etc), then create a subVI that will combine all these together into one image depending on your required settings.  So you could position the horizon line up or down,, rotate it if you are banking etc.
You'll need the Vision package to do the image manipulation - in particular the IMAQ Rotate & IMAQ Shift functions.
Message Edited by LDHGE on 06-08-2010 09:54 AM
Message 3 of 11
(9,000 Views)
Wilmer_S,
The LabVIEW Robotics Module includes an Aircraft Attitude indicator, which may be what you are looking for.
Chris M
Message 4 of 11
(8,959 Views)
Here's what the robotics attitude indicator looks like...
It's an XControl, and we have the following properties...
Message 5 of 11
(8,950 Views)
Hi smercurio_fc ,
I think or you know too much?  Smiley Wink
Message 6 of 11
(8,931 Views)
Wilmer_S wrote:
Hi smercurio_fc ,
No, I've just played a flight simulator or two in my time. Smiley Wink
Message 7 of 11
(8,912 Views)
Ooooooo, I like that horizon indicator in the robotics package!  However, there is a group that has put out a whole set of ActiveX controls for aircraft instrumentation.  You can find that here.  I haven't tried it, but for 150 v 2k, it might be worthwhile (and it comes with some other sweet looking instrumentation also).
Message 8 of 11
(8,895 Views)
Here's the LabVIEW Robotics compass indicator...
On the $150 vs. $2000 issue, keep in mind that LabVIEW Robotics is a lot more than just these controls.  It includes sensor drivers, mapping and search algorithms, a steering API,  obstacle avoidance algorithms, forward and inverse kinematics and dynamics, and more.
Brian
Message 9 of 11
(8,878 Views)
Haha...thanks, Brian.  I am an enthusiastic user of NI products so by no means am I knocking them.  However, if, like me, you only require the woo-woo-ding-dings of a slick display and not all of the functionality found in the robotics package, I will likely opt for the smaller layout.
Cheers, Matt
Message 10 of 11
(8,865 Views)
