ascii data from my serial port does not represent the data I am really receiving
I created a program that sends data to a serial port and then recives new data. I send and recive data as ascii charicters however some of the ascii charicters I am reciving are not what they seem, my serial port monitor tells me that " “.... " equals " 93 00 00 00 1c " in hex. (it also says " 93 00 00 00 1d" is the same) how do i convice my serial reader vi to give me realevant data?
__________________________________
| ( o o ) |
| (") '''' (") Magic Code Bunny ^.^ |
| (m)---(m) |
|_________________________________|
Message 1 of 18
(4,377 Views)
It looks like you use the old* Serial drivers. I suggest you move to the VISA system.
Is the Dumpview your program? Your diagram diagram does not show a write function or 'equals' function so I don't know how I can help you.
Ton
PS as in really old and might be obsolete once.
My LabVIEW Ideas
Message 2 of 18
(4,373 Views)
Im using lab view 6.1, I tried to use VISA but I cant find the COM3 port I'm using. No drop down menu appears when i place a VISA Resource Name control.
The dump view is from a serial port monitoring program (not labVIEW) and shows the output of my program as well as the responce from the divice I am sending info to.
Here are some examples of the problems I encounter.
| ( o o ) |
| (m)---(m) |
Message 3 of 18
(4,355 Views)
Did you install NI-VISA?
Message 4 of 18
(4,350 Views)
I think that version of LV needed an entry in "Visaconf.ini" for it to show in the drop down list.
Is the number of bits set right?
Ben
Message 5 of 18
(4,337 Views)
So is the issue that LabVIEW is not reading the 1D and 1C, or is not writing them?
Note that 1D and 1C are field/file seperators
Ton
My LabVIEW Ideas
Message 6 of 18
(4,332 Views)
The issue is, Labview receives “.... which I cannot do anything useful with. At some point my computer receives 93 00 00 00 1c from COM3 but I do not have access to that info through labview for some reason
| ( o o ) |
| (m)---(m) |
Message 7 of 18
(4,324 Views)
Try right-clciking on your indicator anc choose "slash codes" or "Hex".
Ben
Message 8 of 18
(4,314 Views)
Where are you seeing the "....   ? That is what your dump program is displaying, and if you have the output of your serial read connected to a string indicator it may well show that as well, as the returned "numbers" (actually bytes) aren't displayable characters. If you do have a string indicator showing the returned data, have you "right clicked" on it and selected "hex display"?
I see Ben typed faster that I did!
Message Edited by LV_Pro on 06-11-2010 02:53 PM
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 9 of 18
(4,310 Views)
Kudos to you Putnam for confirming my post before you saw it.
Ben
Message 10 of 18
(4,306 Views)
