assign a shared variable to an OPC server
I am using  DSC module in Labview 8.5.1
I created in a VI a shared variable in a process using "Create Shared variable.vi".
I have an OPC server and i like to assign the shared variable created to this OPC.
The question is: How could i assign the shared variable to an OPC server ? ( i didn't find the toll that does that)
Thx,
Samer,
(2,610 Views)
Correction of the question: How could i assign the shared variable to a variable in the OPC server ? ( i didn't find the toll that does that)
Samer,
(2,604 Views)
First of all I recommend you to check the documentation of your OPC server.
Cordialement / Regards, Matthieu B. @ NI France.
(2,563 Views)
