error iviscope configure trigger
Good morning,
I have a problem with the Iviscope trigger configuration.
I'm using a PCI-5105 Digitizers/Oscilloscopes to acquire 3 channels simultaneously.
I use IVIscope vi to realize the program.
Channels configuration is ok. But when I want to acquire the signals some problem happen.
on version 1.1 of my program the 3 signals are ok but not at the same time. (frequency 1 kHz, voltage +4V, +1V and +2V)
you can see Front panel v1.1 and diagramme v1.1
I don't understand why the signals are not acquired at the same time ?
so I do a second version using trigger vi. (see diagramme1 v1.2 and diagramme2 v1.2)
in this case the signals are not correct (Front panel v1.2)
here I want to use channel3 to trig the 3 other channels.
and with this version, sometime an error message appear (error message Configure Trigger).
Why the trigger channel doesn't work?
Best regards
Florent
(2,708 Views)
the other attach File
(2,707 Views)
