assistance converting this to DAQmx
Hello there. It is my understanding that I will need to convert the following VI to be done with DAQmx instead of DAQ assistant. I'm working on this myself, but I thought I would send the request out to the NI world in case anyone might be able to help.
What I have works great, but I need to basically copy this code so I have 1 input sensor (NI 9205 input module) reading which will control 3 outputs (NI 9263 output module).
Thanks in advance,
Gabe Doherty
Bozeman, MT
(2,219 Views)
Hi gdoherty,
right-click each ExpressVI and choose "open frontpanel" to convert it to a "regular" VI.
Now the DAQAssistent is converted to a subVI containing DAQmx functions…
Don't just "copy code"!
Create a DAQmx task containing your 3 AO channels instead!
(2,218 Views)
