auto caption creation
I have large front panel with more than 200 controlls on it. Some of them have caption some have not.
I want to create caption for all controlls. Is there an easy way to do that?
I have created recursive VI that gives me reference to all controlls on FP but what should I do next??
Message 1 of 9
(5,928 Views)
check the property "Has Caption", if it has caption move on, if not set the property "Caption.Text" = "Label.Text".
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 2 of 9
(5,911 Views)
Accepted by pawhan11
It is probably worth mentioning that the VI MUST BE IN EDIT MODE for my above instructions to work! In order to do this, use the "Open VI Reference" primitive, then get the "Front Panel" property, then controls of said "Front Panel"... All of this MUST be done from a separate VI than what you are trying to set captions. Please see this helpful blog post from Darren.
Charles Chickering
Message 3 of 9
(5,899 Views)
Thanks, I have found it. It works just like You said 🙂
Message 4 of 9
(5,877 Views)
Hi pawhan11
Not sure if you're aware but you can easily get an array of references to all controls on the front panel like this ...
Message 5 of 9
(5,870 Views)
Yes I know that, but when You have muptiple tab controlls,  clusters and so on, getting all references is more complex... Or I am doing it wrong way ?
Message 6 of 9
(5,846 Views)
Use Traverse for GObjects.vi.
Adding to the links to Darren's blog - http://labviewartisan.blogspot.com/2009/06/labview-scripting-tip-1-power-of.html
Jim
Message 7 of 9
(5,838 Views)
Good to know there is something like that 😄
Bad is that I intil now had to write recursive vi to get controlls references on my own 😞
Message 8 of 9
(5,824 Views)
Hello!
I just had a similar task to the original poster (I wanted to get and set captions programmatically) and overlooked an important part of the error message (Error 1320 When Setting a Caption Property). My frontpanel also had too many objects to add all captions by hand. I wanted to stop by to add the direct link to the blog post containing the details behind the answer, as it has moved down the timeline since http://labviewartisan.blogspot.com/2012/02/captions-more-than-you-ever-wanted-to.html
Message 9 of 9
(4,678 Views)
