auto login web page
Hi:
I am writing a LV test program to control a Layer 2 switch. At some point, my test program need to access switch's console web page to read or write information. Problem is that the web page required log-in. I have tried the simple method which attachs username & password in the URL. It does not work. There should be some security implemented. The team who wrote the UI either can't or don't want to offer me help.
(3,463 Views)
Hi Justin,
Did you ever get an answer to this question?  I'm currently in the same situation.  I have to access an Ethernet Switch Web page to enable certain settings but I have to do this programatically as my application is used in a manufacturing environment.  If you resolved this problem and know which approach is best to use to achieve this please get back with me.
Thank you very much.
(3,302 Views)
I stumbled on this sometime back. Maybe it could help:
LabVIEW Forums: Use LabVIEW to login username and password into device IP webpage login prompt
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,282 Views)
