autoscale disable and it autoscales
HI to everyone
I had made a VI in where I need to show 2 graphs, one that shows the pressure and the other one that shows the signal output depending on the programming. allready i made that the pressure graph shows the hystoric and the current signal on a time interval of 1 minute. I can manipulate the time scale on any interval that i want, but with the signal graph i cant do that, i had changed the type of format and it keeps autoscaling even if i dont check the autoscale checkbox and if i change the scale min and max values when i run the VI automatically those values change.
I want to know why that happends and also how can i correct it so both graphs are at the same interval of time
P.D I attached some pics of the VI
Arturo Cortes J.
Message 1 of 1
(2,538 Views)
