autostart application win xp
I have a problem with my executable-application.
I'm using LV8.5 on WinXP SP2.
My application starts automatically due to a link in the "Autostart"-Folder but doesn't work properly.
The problem is that not all NI-Services/drivers are loaded when Windows starts the application.
Is there a way to start automatically my application after all required NI drivers/services have been loaded?
Thank you
Christian
(3,027 Views)
Hi Christian,
one solution for you could be to write another application which will be started automatically. This application checks if all NI-Services you need are ready and if they are ready it starts your application.
Mike
(3,022 Views)
Hello MikeS81,
thanks for your proposal.
Do you know how to check for the NI-services, e.g. writing this routing with LabVIEW, too.
Is there a LabVIEW VI that lists all loaded (non-Microsoft) services?
What NI services do I really need?
I'm just using one NI-MIO data aquistion card (E-series).
Christian
(3,019 Views)
Hi Christian,
i think this can help you http://forums.ni.com/ni/board/message?board.id=170&message.id=88828&query.id=24521#M88828. I´ve attached an example which uses the second solution.
Mike
(3,011 Views)
Hello Mike,
thank you.
I'm going to try it out.
Christian
(2,981 Views)
