average array
I am doing FFT for the signal. I would like to average the FFT results of several times, which means adding and dividing them. Now I have got n*5000 points for n times. But how can I add them after I split the original array into serveral 5000 point parts? Thanks!
Message 1 of 14
(7,391 Views)
Hi Qimars,
attached you find an example to get the mean of columns...
Note:
clean up your source! You don't need to insert data into an empty array (lower right corner of main loop)...
Message 2 of 14
(7,385 Views)
Sorry, I only have Windows2000 system and Labview8.20. I cannot open it. Can you just show me a picture?
Message 3 of 14
(7,372 Views)
Hi Qimar,
sorry, here comes the LV8.2 version.
Message 4 of 14
(7,368 Views)
Hello Qimars,
try something like this. I hope it helps you.
Mike
Message 5 of 14
(7,366 Views)
Hi Mike,
here's a simplified version of your example Smiley Wink
Btw. I think Qimar want to average lines of data...
Message 6 of 14
(7,357 Views)
Hi Mike and Gerd
You two are so warm-hearted. Thanks a lot!
But what I want to get is also an array, not a number.
2*3 array
1 2
3 4
5 6
what I want is 1*3 array
1.5
3.5
5.5
The first one "MeanOfColumn_LV82" seems right. Because it is (Column+Column....)/N = Column. But it doesn't work if I input some data. So can you give me some further help? My output needs to be one Column which is of tpye array.
Message 7 of 14
(7,351 Views)
Hello again,
ok, here a version with Array output. The other example from GerdW didn´t run because of the empty Array i think.
Mike
Message 8 of 14
(7,346 Views)
Hi Qimar,
well, I shouldnt' have used that empty array constant...
Attached version shows calculation for rows and columns...
Message 9 of 14
(7,338 Views)
Mike,Gerd, I got your idea. But how can I change the input array size?
Message 10 of 14
(7,334 Views)
