average array
I don´t understand this question. What do you want to do??
Mike
Message 11 of 14
(1,305 Views)
Hi Qimar,
use our examples as subvi. No need to change the array size, the code will handle different sized arrays...
When using my vi:
- delete the dummy data generation at the left side of the vi
- change the "array" indicator to a control
- connect the array in the connector pane to make it an input
- connect the average-indicator(s) to the connector pane to make it/them an output of the subvi
Message Edited by GerdW on 01-14-2008 02:34 PM
Message 12 of 14
(1,303 Views)
Really thanks a lot. Gerd and Mike.
I got a lot of information from you two.
But how to rate?
Message 13 of 14
(1,288 Views)
Hi Qimar,
rating will be enabled for you when you have a certain number of contributions to the forum. A rating bar will appear in the lower right of messages.
Message 14 of 14
(1,285 Views)
