backslash message
Hi
I need to read a BSON message, when I show the string in a indicator(backslash notation) it is like this:
\03position\00\13\00\00\00\10x\00@\01\00\00\10y\00\00\01\00\00
I don't know how to get the U32 values (in bold)  after x and y position, any idea?
Thanks a lot
(3,406 Views)
Break those 4 bytes out of the string,  use typecast with a U32 constant wired in to convert that to a U32 value.
(3,388 Views)
Than you.
After breaking in 4 bytes, I had to convert it to byte array (U8), then a typecast to u32 to get the value.
(3,314 Views)
Hi Pau,
you don't need to convert to U8 array, just typecast your string (of 4 chars) to U32…
(3,306 Views)
@GerdW wrote:
Hi Pau,
Or use Unflatten From String.  I prefer the Unflatten just in case the data decides to be Little Endian instead of Big Endian.  The Type Cast assumes Big Endian.
GCentral
(3,294 Views)
