bad installer with LV 8.2.1 application builder
I updated LV to 8.2.1 with the update available online. Now I need to build a new installer because the exe will need LV 8.2.1 RT (at least it does not work on a pc with 8.2 installed).
The build process runs fine so far, but when I try to use the installer, an error message with unfullfilled dependencies is shown. I tried to remove a few components but somehow every installer seems to yield this message...
Any hints?
Carsten
(2,833 Views)
hello carsten,
may it possible, that you provide further information?
which dependencies are mentioned?
may it also possible, that you provide a small example project, which reproduces the error?
kind regards,
robert h
NI germany
(2,815 Views)
I kind of solved the problem.
  1. created a new installer spec: the old one seems not to update it's dependencies
  2. deleted the directory where the installer is places: the build process dosn't seem to overwrite all old files as expected
So it seems to be a problem with the project manager not updating the specifiactions correctly (though the directories look ok on the additional installer tab)...
Cheers,
Carsten
(2,806 Views)
