 developer001
			developer001
			04-17-2013 04:34 PM
I want to use a band-pass filter with a high cut off freq of 0.01 Hz and low cut off freq of 1 Hz. My sampling rate is 20 Hz.
Why does this not work?
It works if I switch the cutt of freq values, but I need it to work this way.
I use other applications that do this perfectly, I feel like I am missing something...
Thanks!!!!
 johnsold
			johnsold
			04-17-2013 05:00 PM
It works just fine. If you want all the data suppressed to ~1E-18, that is.
The detailed help file for the Buterworth Filter VI states:
"The values for high cutoff freq: fh and low cutoff freq: fl must observe the following relationship:
0 < f1 < f2 < 0.5fs
where f1 is low cutoff freq: fl, f2 is high cutoff freq: fh, and fs is sampling freq: fs."
I suspect your problem is terminology. You want the high pass part of the filter to cut off at 0.01 Hz, meaning that it will pass everything above that frequency. But that is what LabVIEW calls the low cutoff frequency for a bandpass filter.
Lynn
 MarsianaM
			MarsianaM
			07-11-2017 09:34 PM
Hey, i have a problem with butterworth bandpass filter too..
i am generating Sine waveform, which i can control the frequency, and connected it to butterworth filter with fh 25 hz and fl 3 hz. It does reduce the amplitude, but in the wrong way, i think.. I dont know if i missed something. I just want to testing the butterworth filter in labview, to match the butterworth theory. If you would kindly give me some light, i will appreciate it.
Regards..
 dan_u
			dan_u
			07-12-2017 02:19 AM
In the sine generator you specify a sampling rate of 1000 Samples per second, but for the filter (which does not work on waveforms, but on arrays) you specify 100 Samples per second. That should of course be the same value.
