bar graph in 2 dimension
Accepted by lvrat
Check out this one.
From your description, what you want is to display all different channels value as one time frame, then erase and display the next time frame. Correct?
Message 11 of 13
(1,595 Views)
Thanks that is what I was looking for.
CLD
Message 12 of 13
(1,577 Views)
hanrock escribió:
You can view the 3D dimension in 2D. Shortcut->Visible Items->Projection Palette
I do not know if the XY Graph is able to change the bar width.
Hello I would like to get a graph like that but I also want to be able to get the information of the graph with a cursor, but the cursor in 3d plots are locked to a plot and I want a free to move cursor like in XY graphs.
And also be able to zoom the graph while runing and 3D graphs doesn't allow me to do it.
Message 13 of 13
(1,340 Views)
