basic function generator problem
When I run the the basic function generator VI in version 6.0.2, and set the frequency (which context help tells me is in Hz), something strange happens... I run the generator for, say, 5 seconds at a frequency of 1 Hz, but instead of having an output of 5 peaks and troughs in my waveform (e.g. sine wave) I have thousands and the time elapsed as shown on the x-axis of my display cart is ~2 hours! Am I missing something really obvious? I've used this before and don't remember having the same problem. See attached .bmp.
(3,959 Views)
Don't forget to wire the "sampling info" input with the appropriate data. Default is 1000 pts at 1000 pts/s, at EACH run of the vi !
CC
Chilly Charly    (aka CC)
(3,954 Views)
