best daqmx measurement type for multiple closed loop control system
I wonder what kind of daqmx measurement type that suit for closed loop control system with about 128 control loop?
I have design single closed loop system with continuous sample and on demand sample. Both response good. But I don't know if the control loop number is increasing.
Another question is, is clock time synchronization necessary for this kind of system?
(3,321 Views)
taov,
What do you mean about 128 control loop? Could you explain a little bit more about your app?
(3,297 Views)
Hi Carmen,
Thanks for your reply. Sorry, I made a mistake on my last explanation. That's not measurement type, but acquisition mode. Below is the detail of my project:
I'm developing a control system for fatigue tester with 100 more sensor (load cell) and actuator (servo valve to drive cylinder). Each actuator has its own PID controller. That mean I need about 100 more PID controller. It is OK since PID vi able to handle multiple input in single loop. I used several PXI controller. The thing that bothering me is :
  1. Should I use RTOS for this system?
  2. What acquisition mode is the best for this kind of system? Continuous sampling or On Demand Sampling?
  3. Should I synchronize timing for each PXI chassis?
(3,281 Views)
Accepted by taov
taov,
I would recommend you to use Continuous Sampling since it's hardware time while On Demand Sampling is software time.
As for the RTOS system, please refer to this link.
CarmenC
(3,273 Views)
Hi CarmenC,
Thanks for the link. That answer all my question.
(3,261 Views)
taov,
You're welcome!
(3,247 Views)
