binary to gray scale image
I'm processing a gray scale image.
First I'm converting into binary image to get a ROI.
When I try to extract the ROI from the original image, I'm into problems.
CodeWarrior
Take life as it comes! you may never know what's gonna happen Tommorrow
(4,528 Views)
Could you elaborate what kind of problems you are experiencing?
(4,522 Views)
CodeWarrior
I'm trying to get a particular portion (ROI) of the image that I need to extract it from the original image.
To select an ROI I need to do some preprocessing such as binary thresholding, etc. The problem that I'm facing is that when I extract the image from the original image, I'm not able to get the image in gray scale.
Code Warrior
(4,504 Views)
Your binary image is composed of 1 and O. Just multiply the two images (there is an operator for that) : this will not affect the values of the ROI'ed portions, and will set to black all the others.
CC
Message Edited by chilly charly on 05-03-2005 07:55 AM
Chilly Charly    (aka CC)
(4,500 Views)
Maybe you are having this situation because you are making the threshold at the same picture reference as you wan't to extract your greyscale picture from. Have you tryed to create an other image destination to the binary picture?
(4,495 Views)
