blanks in array data using formula node
I have 2 1-d arrays of data going into a loop. Inside the loop, there is a formula node that combines the numbers from the 2 arrays and does some math to them. If the result of the calculation is 0, that means the value is invalid. Anything other than 0 is a good value. The result of the calculation comes out of the formula node, and leaves the loop becoming a 1-d array. Then my array gets saved to a spreadsheet. The 0's really screw up my graphs, and I would like to have them just be blanks instead. I tried using NaN's instead of 0's, but that also screws up my graphs. How can I put blanks into the output array instead of 0's?
(3,631 Views)
It is better if you post your VI along with some typical data.  It is hard to diagnose a problem from a written description of the VI.
It may be that you need a test for zero and then place the elements in the array only if the data is non-zero.
Lynn
(3,625 Views)
Perhaps one way to do it would be to leave the zeros in the array and change the color to transparent if the value is zero?
I was able to modify the below example to only output 1/2 a sine doing this Smiley Tongue
http://zone.ni.com/devzone/cda/epd/p/id/4467
(3,619 Views)
Thanks for the reply. Here is the VI. This VI is called by another bigger program that gives it the input array and saves the output array to a spreadsheet. Right now it is putting in NaN's which mess up the graphs in excel when I look at the data later. The input array is just a big 2-d (1920x25)array in which all numbers are from 0-255. I would like to just have gaps in the data, like I said before. This way, I can see on my graph where the points are missing from. That's why I not just selectively adding to the array.
(3,609 Views)
Accepted by topic author drhoff
It seems that your real problem is defining what will make Excel leave gaps.  For LV graphs NaNs do what you want.
You might also consider making the output array a string array. There may be string values (NUL?) which will cause Excel to skip.
Lynn
(3,598 Views)
I think you are right. I was hoping there would be a better solution than converting it to strings to use NUL. Thanks.
(3,587 Views)
