count the number of occurences in a text file
hi all,
iam new to Labview, i would like to know
how can we count the number of occurences of a character
in a text file(till the end of file). This text file contains of data(numbers, symbols and characters)
in multiple lines,plz help.
santosh.
santosh
Message 1 of 8
(5,963 Views)
Hi Santosh,
when counting single chars I would do following:
Message Edited by GerdW on 09-14-2006 09:56 AM
Message 2 of 8
(5,958 Views)
Very good example Gerd,
One way to overcome the overflow problem is to implement the solution (shown below) within a loop.  You read the file line by line and keep adding the number of occurrences of each line to the total.  In a document, a single character, such as a space or letter "a" will occur very often.
I think "Read lines from file.vi" could be useful or you can implement something similar to suit your needs.  Another method is to read the text in blocks and index each block at a time for every iteration of the loop.  Make sure you keep track of the end of the file.
RayR
Message 3 of 8
(5,946 Views)
hello gerd,
thanks for ur good reply,
and Joe i request you to provide the example that u r talking about,
i think u missed attaching the file,
regards,
santosh.
santosh
Message 4 of 8
(5,934 Views)
Sorry santosh,
I should have revisited this thread.  I'll try to post an example over the wekend.
RayR
Message 5 of 8
(5,883 Views)
Another option would be to read the file and input the string into the Spreadsheet String to Array function (using your character as the delimiter) and then use the Array Size function on that array.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
Message Edited by tst on 09-30-2006 11:35 PM
___________________
Try to take over the world!
Message 6 of 8
(5,859 Views)
Hey Gerd,
What is the function you were using in that VI?
If you still have the VI itself that's even better..
Yours,
mm035b
Message 7 of 8
(5,242 Views)
@mm035b wrote:
Hey Gerd,
Yours,
mm035b
Which function are you referring to?
  1. String to Byte Array
  2. Index Array
  3. Equal
  4. Bollean to (0,1)
  5. Sum Array Elements
Message 8 of 8
(5,229 Views)
