 gb119
			gb119
			07-06-2009 06:42 AM
 jcarmody
			jcarmody
			07-06-2009 11:35 AM
07-06-2009 01:16 PM
 ! Also, in those cases I don't get the error beep. This is defintiely the cleanup routine finding something it doesn't like...
			07-06-2009 02:38 PM
07-06-2009 05:07 PM
I'm afraid it's a bit tricky to post an example vi as its part of a larger library. However, I do have a screenshot and you can download the code from http://code.google.com/p/lavacr/source/browse/#svn/trunk/8.6.x/Rusty%20Nails/VI%20Scripting/Scriptin... (this is part of the LAVAG Code Repository subversion archive).
The obviously sub-optimal code is around the inplace structure. Note that the code cleanup broke after I stretched the diagram, inserted the two tunnel property nodesand the inplace structure.
For the curious, the code (which is perfectly functional, just not as pretty as it could be) will programmatically create a case structure, populate the cases and set the case insensitive flag for the selector.
10-08-2009 03:47 AM
Hi Gavin,
Just wanted to inform this problem has been fixed in LabVIEW 2009.
Sujay
 Les__Bartel
			Les__Bartel
			09-27-2011 03:20 PM
It seems to be back (broken) in 2010 SP1.
