block diagram freeze
I am experiencing a similar problem with Labview 2009.  I am unable to scroll past a certain point in the block diagram without the program freezing.  I also can't press control+shift+n without it freezing.
Did you ever figure out how to resolve the issue?
Message 11 of 14
(816 Views)
I never did figure out what caused it, but it seemed to went away.  It sometimes acts up, sometimes not.
Message 12 of 14
(813 Views)
Thanks.  I think I might have figured out the probelm.  I think there is something wrong with the Mathscript node.  I tried searching for it (control+f)  and suddenly Labview stopped freezing.
Message 13 of 14
(807 Views)
This is a known issue in LabVIEW 2009.  When a MathScript node is place on the block diagram, LabVIEW tries to load the compiler and a good number of VI's into memory, often times causing the application to hang.  If you need to use MathScript you can try updating to LabVIEW 2009 SP1, but I would recommend upgrading your version of LabVIEW to fix this issue.
Alexander M
Message 14 of 14
(785 Views)
