boolean array
Hello to all,
Welcome back.
I would like to ask you a question:
I would like to concatenate a string array with a boolean array ...
Is it possible?
Thank you very much!
(3,287 Views)
All elements of an array must have the same datatype, so you cannot concatenate them directly.
(You can e.g. make a cluster of the two arrays). Please explain why you think you need this. What is the use of the resulting data structure you want. I am sure there is a better solution.
(3,283 Views)
Thank you for your immediate response.
I have a table (from an array) whose rows show various temperature data.
I do turn on a green LED when the temperature goes well, an orange when it rises above a limit and a red when it exceeds a maximum threshold. All this I would do it in the same table (as a matter of order).
(An alternative would be to paint in green, orange or red rows in the table, depending on the case ... but I do not know if we can do.)
(3,277 Views)
You could change the table cell background or font color according to the boolean value.
Here is a link discussion a simple example.
(3,267 Views)
