read write multicolumn listbox
Hello!
Please help! I can not understand! How to write and read data from a file into multicolumn listbox? Please give an example. I have a multicolumn listbox size of 10 rows of 10 cells.
Necessary data from this multicolumn listbox to write the file (preferably ini). Then, the recorded data is read from a file in a multicolumn listbox.
(6,500 Views)
Multicolumn list box contains data in 2D array of string data type. You can use property node "Item Names" of multicolumn list box to read and write the data and property node "Value" can be used to index the selected row of data.
(6,487 Views)
Accepted by topic author 1111111111111111
You can read/write to/from its ItemNames property.
(6,486 Views)
