broken wire
hello everyone
 i am beginner in Labview and i am trying to connect this two vi  , but to no avail
Anyone have any idea how to solve this problem i will be so grateful Heart
(4,612 Views)
The tooltip explains exactly what the problem is.  The output of the FFT function does not match the expected input of the peak detect function.  More specifically, the FFT function output is a cluster of values (frequency domain) similar in structure to, but not the same as, a waveform.  The peak detect function operates on a (time domain) waveform.  You can't wire the two together.  You can, however, tie the peak detect to the waveform wire you already have just above that function, but I suspect you weren't looking for a time domain peak.
(4,561 Views)
Accepted by anoir1993
Here's a way to convert your freq domain info into a waveform datatype.  It's kinda ugly but will probably get you started. You may need to experiment a bit to discover exactly how scaling of inputs and outputs (such as width and derivatives) is affected by this attempt to trick the peak detector into operating on freq domain data.
- Kevin P
(4,553 Views)
it's working thanks a lotHeart
(4,522 Views)
