buffer problem?
 i put the visa resouce number in the while loop but the same problem keeps occuring, maybe it's the hardware that has problems ?
Message 31 of 48
(3,032 Views)
I think you misunderstood me.
Run your hotplate VI with highlight execution set to on.
I think you'll see that you try to open the VISA resource twice and that on the second try, it will error out.
Message 32 of 48
(3,029 Views)
i took out the VISA open is this waht you're talking about? however, it's still having the same problems.
i emailed the company and they said it has something to do with the delays so i'm currently playing around with that right now. thanks so much for the input!
Message 33 of 48
(3,018 Views)
Can you post your updated VI?
Message 34 of 48
(3,008 Views)
here's the updated vi
Message 35 of 48
(3,001 Views)
The while loop in the attached screenshot is your problem.  You call Open VISA when iteration is equal to zero and again when iteration is equal to 1.
The second call to Open VISA likely returns an error and invalidates the reference.
Please take the time to apply the other corrections from my previous post to this VI as well.  If you intend to keep using this VI, I think it is a good candidate for refactoring.
Message 36 of 48
(2,977 Views)
No.  Opening a VISA reference that is already open will not cause an error.  Also, if you don't explicitly open it, it will open itself the first time you try to use a VISA function.
Message 37 of 48
(2,973 Views)
sorry, the hotplate.vi program is not the finished program, it's changed to hotplatefinish.vi if you can help me with that one?? thanks!!
Message 38 of 48
(2,966 Views)
and using the visa open for this vi also didn't make a difference. still getting the error :S
Message 39 of 48
(2,965 Views)
For the visa write return count, it reads numbers but at random times for the visa read, it stops working as in it returns a value of 0.  has anyone had an issue with this?
Message 40 of 48
(2,950 Views)
